Error Code
Trennaa
37
Melbourne, AU
Qwerty
Hi guys,
I have had my car on the diagnostics run with the mechanic, he pulled up two error codes (Oxygen Sensor, which has been fixed) and "31 Theft Deterrent System – Missing Signal" <- what normally causes this. The memory has been cleared, and just waiting for the engine light to come back on, but have no idea why it would appear
fitzy2005
Wide Bay, Queensland
VY S2 Berlina
tr3nt said:
Hi guys,
31 is a weird one, for sum reason soon as i short pins 5 and 6 and shut the door in turns that anti theft deterent red flashing light off
nothing to worry about i doubt
Stretcher Bearer
A.R.N.G.
VT2 SOCOG Exec 9C1
Now and then the ECU and the BCM don't communicate properly, such as a dirty connection between the key and the igntion, sometimes with it you can get the immobiliser light flash faster than normal.
You can still start the car and it doesn't cause any drama I would imagine unless it is a persistent fault.
