Eurovox Radio - Reset PIN
Discussion in 'Car Audio' started by Tekit, Mar 28, 2005.
  1. Tekit
    Tekit Guest
    Eurovox 6616 Am/Fm cassette radio with security
    I picked up a cheap Radio at the wreckers for $10, and last time I just went to Holden and they gave me a code that was for my VIN and it worked for a radio that wasn't mine ?
    This time they wanted $50 also they wanted the VIN it came out of as it was on the seat of the car not in the dash I don't have it. The wrecker said I could bring it back but then I would have to pull it out of the dash again.
    The point that comes to mind is if one code worked in 2 radios then more than likely there are not many codes per radio type used by Holden so if we get a list of codes that do work against a model type, this would limit the attempts it would take to get a radio working.
    Come Holden and Eurovox these are 10 year old cassette radios.
    I contacted Eurovox and they will give the code based on the serial number for $22.
    As a note :
    If Holden are putting hundreds of radios (with pins in them) into cars per day and are also recording the individual pins in the car computers and in a database. don't you think this would be problematic? since it would have to be recored against the radio serial number and VIN for both Eurovox and Holden.
    If they programmed the radios after the install with the code then they must be an override code and/or key squence. (other car manuf. do this).
    If a batch of radios have the same pin then it would be easy to record the pin against the VIN and Eurovox already have it recoreded against the serial number. We just need the list of pins to batches, model.
    Code generators are easy to find for BMW , merc and all other euro cars but not Holden , why ?, probably the same reason you can get acircuit diagram for them.
    Ok I've had my whine :b:
  2. KAL SPL
    KAL SPL Member
    Orange Nsw
    Blown VS Calais !!
    Takes 10 minutes tops
    If longer then the dealer is lazy or trying to make money out of you , just go somewhere else.
  3. Tekit
    Tekit Guest
    But can a Holden dealer do it via the Serial number of the unit instead of the VIN number.
  4. KAL SPL
    KAL SPL Member
    Orange Nsw
    Blown VS Calais !!
    They sure can :)
  5. cliffo78
    cliffo78 New Member
    VZ SV6
    I noted that the code for my old VR radio was the same as someone else that posted their PIN on this forum. From memory it was 5214. So maybe there are indeed only a few pins issued for each model of radio, as Tekit suggests. Thoughts anyone?
  6. gibbo
    gibbo Member
    Toyota Hilux 3.8l vs v6 & 4L60E
  7. Tekit
    Tekit Guest
    $5 for the Pin
    I finally had some success (partly) I found a Holden dealer that will get the pin for $5 but the need the VIN from the original car as well as the Serial as there search is on VIN ? Is there someone out there that can confirm this ?
    I've got the PDf for Eurovox but its $22 and I have to get proof of ownership and an Fpos receipt won't do.
    Crap :cry:
  8. cliffo78
    cliffo78 New Member
    VZ SV6
    As far as Holden is concerned I think they link radio PINs to the VIN of the vehicle it is being installed into on the production line, so maybe they dont include the radio serial number in their database.
    Eurovox has verbally told me that if I buy a radio from somewhere that doesn't provide a receipt (ie eBay), I can sign a stat dec saying that I am the owner. I checked this once when I was bidding on a VT CD/tape/radio which didn't have the PIN and the seller didn't know the VIN of the vehicle it was out of. So if Holden can't help you and $22 is the cheapest option then ring Eurovox and tell them you bought it off eBay!
    Out of interest, which Holden delaer was it - do they give PINs for $5 to anyone or do you have to "know" someone there?
  9. Secki
    Secki New Member
    Southern Highlands
    VH Wagon SLX 253
    the manufacturer should be able to give you the pin also depending on how legit they think you are. Holden dealers are scum, one dealer wanted 30 bucks off me, i went to another and he gave it to me for free
  10. gibbo
    gibbo Member
    You have to realise they charge for this as it takes up so much time, if a few people walk in every day wanting a security code and the dealer has to spend 10 minutes (or more because the person wants to tell them their life story) each time then they are using up time not doing the rest of their job (which they are getting paid for).
    No I don't work for a Holden dealer!....
  11. Doctor Bob
    Doctor Bob Grandpa
    Retired
    RG. Colorado & Caravan
    I do work at a Holden Dealer & if you can get it for free more power to ya
    but as gibbo said we get 10 to 15 enquiries a day, and cant afford to have someone sitting there all day getting pin numbers can we?...
    and you wonder why dealer labour rates are so high.lol
    and yes the online database we use is searched by VIN.
    Cheers Rob
  12. mixin
    mixin Ol' fart, young heart!
    Country Vic
    I've found if you are buying parts, then the guys in spares will normally get you the code for free, but if you walk in off the street & ask, without buying anything else, they will charge for it.
  13. Crispy
    Crispy Guest
    Radio PIN for Eurovox
    If you ring the dealer that sold you the car they will generally give you the radio PIN over the phone at no cost, at least this was my experience at Eagers in Brisbane :yeah: .
  14. KAL SPL
    KAL SPL Member
    Orange Nsw
    Blown VS Calais !!
    If they had to physically do something with the car then I could understand but all you need to do is hit a few buttons on a computer and it pops up for them , I dont see it being any harder than printing a reciept and they dont charge for that.
  15. Tekit
    Tekit Guest
    I got my code
    Ok it did only cost me $5 cash, they sighted the car and radio, faxed off the serial number with my VIN and the code that came back worked fine. They used my VIN off my VN, as the radio was the same type that came in it originally.
    Motorama Holden , thankyou
  16. Doctor Bob
    Doctor Bob Grandpa
    Retired
    but its still time isnt it, if it was your business & your employees were doing freebies you wouldnt appreciate it would you.
    Cheers Rob
  17. 05vzute
    05vzute Banned
    campbelltown area
    2005 VZ ute
    hey everyone, im new to this stuff...read alot on here but haven't been bothered to join.untill now haha....i used to work for holden as an apprentice and picked up a few things along the way..including usernames and passwords ;)...from what i gather at holden, they jump on a website call gmglobalconnect.com...from there they log in and do specification and tracability checks using ur VIN...if you want your radio pin, send me an email to bodyboardlife93@hotmail.com saying you want ur pin and i also need ur VIN im not 100% sure if its gunna work...koz i've tried to do a few check on different cars of different models and it may work on some models but not all...however, this will only bring up original radio pins..if you've had a different one put in it might not work, as i said, im not 100% sure, but i'll try my best..cheers guys
  18. 2005vzute
    2005vzute Djabringyagrogalong
    Glenfield 2167
    2005 VZ Ute M6
    well thanks to some dill that has reported me as a spammer i had my last account banned...sorry for the confusion..i didn't even think about looking like a spammer by copying and pasting the same message ^as above, from 05vzute...the point was to make sure i make myself seen across the different forums about radio pins and to get all the people having trouble with getting their original radio pins to contact me before going to holden and paying up to 50 bux when i can do it for nothing..again..sorry for looking like a spammer, didn't mean to..cheers guys
