Explained: Why Some Engines Have Both Port and Direct Injection
Skydrol
USA
Pontiac G8 GT
https://www.caranddriver.com/news/a...-engines-have-both-port-and-direct-injection/
DON SHERMAN
May 2, 2017
Half of the U.S. new-car and truck fleet now is equipped with gasoline direct injection (also known as GDI)—which means the fuel is sprayed straight into the combustion chamber. This begs the question: What’s the next engine innovation about to leave the lab?
Toyota’s D-4S system was introduced on the 2006 Lexus IS350 3.5-liter V-6.
Ford currently is the dominant player with what it calls dual-fuel, high-pressure direct injection (DI) and lower-pressure port injection (PI). Applications include turbocharged and naturally aspirated V-6 and V-8 gasoline engines—four in all—ranging in size from 2.7 to 5.0 liters. The 2017 F-150 Raptor flying pickup and the GT supercar both are powered by new 3.5-liter EcoBoost V-6s so equipped. Ground-bound F-150s also rely heavily on this technology with a dual-fueled base 3.3-liter V-6 and optional EcoBoost 2.7- and 3.5-liter V-6s. Ford’s most recently announced application thus far is the new 5.0-liter V-8 that will power the 2018 Mustang GT.
The Basics
Before delving into the fine points of teaming PI with DI, a short primer is in order. Contrary to Hollywood’s depictions of cars plummeting off cliffs, there is no such thing as spontaneous ignition. Because liquid gasoline won’t burn, preparing fuel drawn from the tank to combust inside the engine is a two-step process.
Step one is atomizing the liquid to fine droplets, achieved by forcing gasoline pressurized by a pump through tiny injector orifices. A study by Hitachi engineers revealed that fuel pressurized to 1000 psi and injected through orifices ranging from 0.006 to 0.011 inch in diameter yielded a 135-mph mist of droplets only 0.000003 inch in diameter. That’s fine.
Vaporization follows atomization. Here, the fine fuel droplets go through a liquid-to-gas phase change, becoming a vapor that can be mixed with air and ignited by the spark plug.
Because heat is absorbed during this phase change, there’s a cooling effect, which can be used to improve the engine’s operating efficiency. With PI, the air flowing through the intake manifold is cooled before it reaches the combustion chamber. With DI, the cooling benefit occurs within the chamber itself.
Ford equips several EcoBoost V-6 engines with dual injection, including its GT supercar.
Each strategy has pluses and minuses. PI is handy for naturally aspirated engines because cooling the incoming air increases its density and power-producing potential. It’s significantly easier to locate injectors in the intake ports, well away from the valves and spark plugs. This upstream location provides ample time for full vaporization to occur. One downside is that fuel droplets sometimes are deposited on the intake port walls, upsetting the intended fuel-air ratio.
With DI, the chance of detonation—premature ignition of the fuel and air mixture—is diminished because the phase-change cooling effect takes place during the compression stroke just before ignition. Lowering the combustion chamber’s surface temperatures enables a higher compression ratio and improved efficiency whether the engine is naturally aspirated or boosted. Ford raised peak torque by 30 lb-ft in its new 3.5-liter V-6 by combining the new dual-injection strategy with higher boost pressure.
There are downsides to DI. A DI system is more expensive because the pressure required to squirt fuel into the combustion chamber is 50 to 100 times higher than with PI, and the higher-pressure pump imposes parasitic losses. Direct injectors tend to be noisy. Carbon deposits—both on the backsides of the intake valves and on tailpipes—are service issues for some DI users. Because there’s less time for vaporization to occur, some fuel escapes the combustion chamber and the catalytic converter as particulate matter or soot. These carbon particles are similar to but smaller in size than those spit out by diesel engines.
The Combination
The ultimate strategy is combining both PI and DI benefits, using each to diminish the other’s negatives. Toyota, for example, fires both injectors during low to medium load and rpm conditions—in other words, during normal driving. This raises the density of the incoming charge without boosting and flushes carbon deposits off the intake valves. During high load and rpm circumstances, when maximum combustion chamber cooling is needed because detonation is more likely, DI handles all the fuel delivery.
Each maker uses a different strategy regarding when to use port, direct, or both injectors. One of Toyota’s torque versus rpm versus injector use maps is shown here.
Peter Dowding, Ford’s chief engineer of powertrain gasoline systems, revealed a different strategy. Ford uses PI alone at idle and at low rpm for smooth, quiet, and efficient engine operation. As rpm and load increase, fuel delivery becomes a programmed blend of PI and DI. In contrast to Toyota’s methodology, Ford’s PI is always operating, responsible for at least 5 to 10 percent of the fuel delivery.
Dowding and his Ford engineering colleague Stephen Russ stress that carbon deposits on tailpipes and intake valves have never been an issue in their DI engines. Dowding adds: “Now that electric motors are being assigned increasing propulsion roles, our task is to improve engine efficiency whenever we can. Ford’s dual-fuel technology has already proven to be a valuable, cost-effective strategy in this effort.”
Explained: The Atkinson Combustion Cycle and Its BenefitsEngines au Naturel: An Unfettered Look at Significant EnginesWatch Internal Combustion in Action with This See-Through Engine
Designing and developing modern engines is a juggling act that attempts to balance power, emissions, mileage, durability, drivability, and other concerns. The dual-fuel strategy gives engineers an additional key to turn as they strive to unlock more energy from each drop of gas. As lessons are learned and component costs fall, expect more makers to adopt this approach to fanning their fires.
Brettly-2008
Vasse
SS Commodore - Ford Territory ... both camps
Interesting read. 1000psi is staggering for a production engine when you think about it.
07GTS
Australia
VEGTS BUILT BLOWN E85
the gen5 boosted chevs are pushing close to and some prob even over 3000psi, the issue is what u could inject during port style in a continual 720 deg engine rotation the DI only have maby 3-6ms time to inject and there gets a point where so much fuel is injected at once in such a short time it just dosnt go thru the combustion right so adding extra port injectors helps with the boosted engines to keep DI for emission but port injectors for WOT power
Immortality
Staff member
Sth Auck, NZ
Are you sure you aren't our old friend Pir4te in disguise?
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
The LT5 needs both systems for its rated output.
Continuous DI, and using PFI similar to a 'staged secondary' set up.
Immortality
Staff member
Sth Auck, NZ
I've seen a few LT4 builds from the US. They make close to a 1000(US)rwhp on pump 93. Many though go for flex fuel E85 as well as Methanol injection to support the DI. They also use cams with larger lobes for the DI pump to increase flow as well as external booster pumps to supply more fuel to the DI pump.
Skydrol
USA
Pontiac G8 GT
The reason I posted that article, I was watching this guy. An old "wrench" that has a video blog, a bit kooky but if you listen to the message instead of how he present himself, he does make some good points. He was talking about Catch Cans and mentioned the Dual Fuel System. I think he does have a valid point.
Immortality
Staff member
Sth Auck, NZ
Yes, with DI engines the catch can becomes more critical.
My apologies for the sidetrack, talk about the Atkinson cycle is right up the alley of our old mate.
Skydrol
USA
Pontiac G8 GT
Is ok, I see no harm.
