ScottB_33
Go Hard or Go Home
- Oct 3, 2005
- 258
- 3
- 18
- Age
- 56
- Location
- Nowra
- VTII Berlina Supercharged
I was searching the other day and found that the rear wiring for the Amp and rear parcel speakers is in place in my VTII Berlina. Once I had connected the Amp and speakers I still couldnt understand why it would not work :bang: . I investigated further and found that the fuse for the Amp has only one connector fitted, so therefore no power is going back down to the Amp to make it operate. Once I removed the fuse cover and other trim pieces and the drivers kick panel, I simply placed a patch wire into the fuse box, from the missing side of the fuse and then connected into the harness connector behind the kickpanel and behold :w00t: the amp fired up into gear!!! So if you have the rear harness already fitted in your car for the amp and speakers, then the patch harness will get everything operating!!! :thumbsup:
