Faulty ECM or Stretched Timing Chain?
Fu Manchu
WA.
•May 07 LE0 Crewman (base model)
Had the car indirectly diagnosed has having a possible stretched timing chain.
Symptoms are there but not entirely.
The technician who looked at it wasn't entirely convinced the timing was the issue.
Problem happened quickly.
The thing that bugs me is symptoms are also similar to a faulty ECU.
Also shifts a bit wrong. Wont kick down so easily.
Leading up to fault codes being logged was an intermittent start fault. Turn the key and nothing. Like when the starter is a bit dickie.
•So is there a way to test the ECM?
•How is a stretched timing chain diagnosed for certain?
I have a diagnostic cable arriving soon and will be able to take a good look at what it's doing while I drive etc.
Adventra LX8 & LX6
Timing chain stretch will dump codes for cam position error and most importantly rattles like a MoFo on startup cold..
figjam
Donating Member
Far Kurnell
FJ
Info gleaned from this forum....................... The engines with timing chains susceptible to elongation were produced from January 2006 to engine build date 18 May 2007 (18/5/2007); this production range corresponded to engine numbers between H053340001 and H071380576.
Is your engine number one of the ones likely to be effected ?
Fu Manchu
WA.
yeah have read that and yes the number falls in that bracket however I am looking for info relating to what evidence is needed to diagnose either fault. guessing is not ideal when such a major expense may not even be needed.
It is logging codes for cam and oil. If the ecm is faulty then that may not be true and hence why the Roadside technician wasn't so sure it was the timing. The car ran to well for that IHO
TazzI
Envyous Customs
Western Australia
www.envyouscustoms.com
Holden VE SS Ute
Normally when its ECU, you will see the following fault display on the dash:
- SVS (Service vehicle soon)
- Fuel gauge error
- Check Powertrain
You will also find the car starts intermittently (like you are getting) and when it does start, it will run extremely rough as injectors begin dieing. Commonly injector 5 dies first which *sometimes* a fault is logged for the cylinder/s having problems.
figjam
Donating Member
Far Kurnell
FJ
Again, info from this forum, but you may already be past this point.......
Elongation of the timing chains would cause,
•the Malfunction Indicator Lamp (MIL or ‘Check Engine’ light) to illuminate; and
•the ECU to log fault codes P0008, P0009, P0016, P0017, P0018 and P0019 which indicated that camshafts on either bank of the engine were misaligned with the crankshaft.
Fu Manchu
WA.
Great stuff folks.
When I get to plug the car in I will know more for myself.
As it happened, we started to get the engine light appear on our VE Calais and now saying oil pressure issue. :/
Adventra LX8 & LX6
Great stuff folks.
Oil pressure sensor.... Common as..
TazzI
Envyous Customs
Western Australia
Holden VE SS Ute
Great stuff folks.
Any update??
gungazza
67
west suburbs
executive vt 5.0lt VZ CREWMAN
my engine no is 10hbhHO60400096 WHICH IS IN THE RANGE CREWMAN DONE 205000M SEEMS OK AT THIS STAGE TOUCH WOOD
