PlenumBiscuit
- Dec 22, 2010
- 1,390
- 147
- 63
- Location
- Adelaide
- VY Commodore
1: How do i get the front pillar off above the drivers door does it just pop out. I wanna feed a phone charger cord up to my phone on the window mount
2: where to get best double side tape that will hold the doors trolley guard back on?
3: if changed all 3 mounts, engine and trans and theres still a vibration what could it be? VY fault list says exhaust might need a spacer? But mines a july 2004 (the final build)
4: whats the quickest way to get the pcv valve out
5: how to stop front brake squeel
6: is there anywhere or way to add a 2nd usb port
7: using 12 litres fuel per 100kms what would u buy first a new fuel pump, new oxygen sensors or new injectors
8: when car heats up should both radiator fans be coming on because on the passenger side fan kicks in
9: i rounded the tiny nut that holds the exhaust outlet pipe in on back of throttle body, how can i crack it. I think its now a 9mm
