FIX STEERING WHEEL
Jimma61
Cheltenham
Vu ute
Hey guys has super cheap or bursons got a bond or glue that can be injected into steering wheel to stop it from moving back and forth? What have people done instead of replacing the steering wheel
sebbas103
thornton
VT COMMODORE
get a big syringe and large needle from chemist, pull the plunger out, mix some epoxy, fill siringe from that side then inject it from the inside of the steering wheel in about 4-5 spots and twist the loose parts to spread/flatten glue. Leave overnight to set.
once you mix epoxy work fast.
Worked for me :)
gtrboyy
vt ss & lc gtr
Try not to stab yaself...
Got a vr wheel to do also..got the syringes just not sure what will work best bonding the rubber & metal that's injectable.
oska
vx custom 600RR
The best glue to use is Loctite 480
sebbas103
thornton
VT COMMODORE
yeah we just used a cheepy 2 part mix up epoxy, failed the first time, combination of buying a fine needle and smaller siringe, second time used a large siringe and thick needle and worked fast, worked wonders.
