88GreenVN
Next Exit Left
- Jun 12, 2006
- 6,795
- 136
- 63
- Age
- 60
- Location
- Surprise, Arizona
- Dodge Ram Van 1500 5.2 V8
If you need to replace the LCD screens in a Level 3 trip computer - one major problem can be the white plastic fascia snapping the mount holes.
Here is a way to fix it if you have most of the bits rattling around in side still.
1. Take the trip computer out of the cluster and flip the screens over and remove the 6 screws holding the PCB onto the fascia.
2. Remove the 3 LCD screens after marking them L - left m - middle - r right.
3. Super glue the small parts (only use small amounts of glue here) back in place taking care not to get any in the threads - your just looking to hold in place at this point
4. Cut 4 thin strips of 25mm sticky tape about 5mm wide and cover the 4 holes along the bottom of the fascia.
5. Mix some 5 min araldite - about a 20c worth and using a strong type tooth pick place the glue in and around the holes in t steps. First put glue in all 4 spots and push down into the slots. Then as it sets make sure all 4 mounts are coverd at the top
6. Within an hour you will need to trim the glue with a sharp knife/ofler blade so that the LCD screen fit back in. Also remove the sticky tape from the front of the holes.
7. You then repeat for the top 2 mount holes with small aount of glue so that the glue joins the mount peg to the sides for extra strength.
8. Trial the LCD screens for fitment and put the 6 screws back in. Some times the alignment is not so good and may need to repeat this step if screens are pale. If after several goes the LCD screens may infact be dead.
9. If you get a screen with no segments at all you may have put it in upside down.
10. I recommend running T4 Neo Wedge LED's in place of the globes to reduce heat. They are much cheaper to buy also.
Also you can use this thread to ask any questions about trip computers or LCD screens you may have.
