Vonrottes
- Oct 29, 2020
- 63
- 101
- 33
- Age
- 31
- Location
- Columbus, ohio
- 2009 Pontiac G8 GT
Been searching for weeks but can't find a definitive answer.
My 2008 g8 GT has a clunk coming from the front end somewhere, going over small bumps, it gets worse when it's below about 10c, and mostly goes away above 23c. Can't feel anything in the steering wheel, but when it clunks you can kinda feel it in the floorboard, sounds like it's coming from the front right side.
Have replace strut mounts/bearings as well as sway bar end links.
Checked the LCA and radius arm today felt no movement in the wheel and saw no vertical movement in the bushings with a pry bar, though imo they allow quite a lot of horizontal/twisting movement..
Exhaust all seems to be tight/secure.
I did see one person in another forum mention bad engine mounts as a possible clunk in the front end, mine look like they could use replaced soon but have no visible rips or leaks.
All help is greatly appreciated.
Just trying not to throw parts at the issue.
