'Frozen' Indicator
HowMat
Cardinia Area
VZ Lumina
Hey all, my VZ indicators started sticking and not doing the usual on/off flicker yesterday, and today they're cactus? Is it a fuse problem, or wiring, or even an electrics problem? Any help would be awesome as this is my day in day out car for everything,
cheers
Sent from my iPhone using Tapatalk - now Free
Super_Low 91
┌∩┐(◕_◕)┌∩┐
Aussie
1993 VR
Sounds like it mite be the flasher relay or if the indicator stalk is not working properly it could also be that. My money is on the flasher relay tho
Sabbath'
Redblock Jesus
80 Series// VFII Black Edition
VZ's had a BCM issue. Do a search there are a few threads about it.
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
Don't go delving into the guts of the circuit first.
More than likely it's just the flasher unit.
Had one go on an EF falcon. No flash, just stayed on.
Had to flick the stalk on and off when I had to turn.
Easy cheap, 5 minute fix.
adamcawood
mooroolbark
VZ SV6
Hi mate I done mine not long ago the left was sticking bad I got the relay off eBay was like 12$ and de soldered it and the replaced with new relay took less then 1 hour where abouts are you located ?
HowMat
Cardinia Area
VZ Lumina
I didn't think I had to solder and in solder a relay? RELAYS WERE SO EASY ON VS'.
where do I find the point for the indicator relay? doesn't seem to be in the fuse case under the bonnet? probably just tired from work,
thanks for the link!
VZ Lumina
adamcawood
mooroolbark
VZ SV6
Up under the dash above the pedals there is a bcm you need to take that out then open the case up there will be a little relay on the circut board you need to replace that
HowMat
Cardinia Area
VZ Lumina
thanks!
and yes. The VS' were so much easier to replace relays! :p
VZ Lumina
