smaddock
- May 2, 2005
- 148
- 1
- 0
- Age
- 45
- VS V6 Executive S2
I have for sale a brand new regrind cam and chip package to suit a VS V6 auto.
The cam is from Surecam and the profile is their High Performance Street cam, which has 221deg. duration @50thou, and 280thou lobe lift, with 110lsa.
The chip is to suit this cam and is from Chiptorque.
Since it is a regrind, and there has been a little meat taken off the base circle of the lobes, I've also got a set of 50thou longer pushrods to go with it too. These are Manley chromoly race pushrods, 7.100" length, 5/16 diameter with 80thou wall thickness.
I've had the same profile cam fitted to my engine, and made a best of 141rwkw with standard heads, and just extractors and 2.5in exhaust. Also ran a best of [email protected] with this combo, with shift kit, and single spinner 3.08 diff.
Its recommended that a heavy duty timing chain and valve spring upgrade be done when fitting.
Will not seperate the cam/chip/pushrod set.
$600 for the lot.
Remember this is a brand new cam (regrind), the chip has been used before as have the pushrods, however they only saw about 1500kms in the engine.
Can supply dyno sheet if you like, as well as time slip for proof of performance.
Either PM me or call 0418 225 044. I'm located near Frankston, Vic.
$600 for the lot.
