Fuel consumption increased after installing manifold insulator/ spacer
Anthony .
NSW
1994 VR V6 Executive
Hi all,
My fuel consumption on my VE sv6 used to be about 13.5L per 100km around town, and around 11L per 100km when on the highway.
Since installing the insulator, I am getting 15L per 100km around town. If I reset the fuel consumption meter whilst travelling at highway speeds, I am getting about 9L per 100km (positive improvement).
I drive normally and don’t WOT often at all.
Is this normal? I drive exactly the same way I did prior to the installation (maybe a touch more gentle since they provide a touch more torque down low).
The spacer has been on the car for about a solid week now.
I thought fuel economy improvements were to be had more generally rather than only on the highway.
Is this normal?
krusing
Melbourne, Bayside
May need to smoke Test it !, [Vac leak ?]
I would give it more than a week to evaluate it,
Being you are so used to looking at it randomly,
Now you are looking it all the time,
The system works on an average over a tank, and how it "was" driven
Also depends on the fuel you have filled it with,
There is a lot variables for the averages
IMHO, give it a month for your averages to level out.
Anthony .
NSW
Cheers.
Could it also potentially be an improper seal of the gasket maker? Shouldn’t be since I let it dry overnight
Fu Manchu
WA.
I did away with the sealant and used two metal intake gaskets. I cut the nodule off one.
There is likely a vacuum leak and most likely from a hose rather than the insulator.
@krusing mentioned the smoke test of the intake plenum. Just about 100% finds a vacuum leak.
