The factory filler neck is still on car,tank is out.
It does have the short thick rubber piece, but it's still on the filler tube.
Took tank out to clean the return hose bits out.This is on a series 2 VS wagon,I got a sender unit from a VS wagon at upullit and the return hose was the same as this one,yellow and snapped off at the quick connect fitting. I'm not sure if this is wagon specific thing but I may go back to upullit and see if it has the same insert although VS are getting scarce at upullit.
