Fuel leak from injector rail tube?
Mike304
44
Tweed
Statesman 304 vs
Hey guys, vs 5.0 stato has fuel dribbling out of the back of the end of the injector rail on the passenger side.. It's a fair leak and runs down onto the exhaust... Thought it was the last injector so replaced top and bottom O'ring - still leaks.
Is there an O'ring that goes into the injector rail tube at the back? Super hard to source... Thx in advance.
losh1971
North Tas
VE Series I SS Ute
Is this a factory rail or aftermarket?
losh1971
North Tas
VE Series I SS Ute
@someguy360 had this or a similar problem. His engine caught on fire.
Mike304
44
Tweed
Statesman 304 vs
That's for the VS V6 but might have what I need? Or you reckon just get a new rail or a wreckers
Immortality
Staff member
Sth Auck, NZ
It's been a long time since I looked at one but fairly certain there is an O ring in there.
someguy360
The Shed
Various
There is o rings on all fittings that go in and out of the rail.
It’s likely leaking from the fitting out the back.
Did you lube the o rings when you put them in, if they went in dry (heh) they’ll leak.
Speaking from someone who’s had a fire in that back corner from the fuel rail, be careful!
Mike304
44
Tweed
Statesman 304 vs
Yeah mate lubed up... I'll just have to try and track down that O ring
Fu Manchu
WA.
Or try a thicker o-ring maybe. Like @07GTS did on his injectors? Maybe worth a shot? Or is the o-ring thin and fit a groove?
