Fuel problem
kezzaj666
44
Hunter Valley NSW
vr commodore ute, Manual
so normally my VR ute is excellent on fuel, but today i changed my fuel filter and went out and its chewing fuel like crazy i used half a tank of fuel on a trip that was only half hour each way. Last week i changed my spark plugs,and oil etc and had no problem until today when i changed the filter...any ideas what could be causing this.
FATMOE
VY Clubsport R8
Judging by what you said ^^^, you probably haven't hooked up your fuel filter properly. Get under the car and check for fuel leaks. Did you install the correct way????
RX25SE
Real cars are steel cars.
MY07 Liberty 30R Spec B 6sp wagon
+1 for fuel leak
James39
Gave up on VL's
Newcastle NSW
1995 VS Acclaim & 1992 Holden Barina
In a sense you answered your own question, check for leaks where you replaced the filter while the engine is running.
kezzaj666
44
Hunter Valley NSW
it is installed the correct way i double checked it thismorning and there is no leaks at all also checked that as well
kezzaj666
44
Hunter Valley NSW
checked both with the engine running and with out the engine running
