If your wiring is like:
Code:
+-----+ +---------fuseb-------pump---earth
! BAT !----fusea----Relay----+
The wire from the batttery to the relay must be able to cope with twice the current that the wires from the relay to the pump can cope with.
Thicker copper wires are able to can carry more current than thinner wires while insulation thickness is more than required primarily for mechanical wear reasons. Also a wire's current capacity is downgraded by some safety factor to handle environmental heat issues and some overcurrent. This gives a base current capability that the specific wire can handle. A circuit is then normally fused at level which is some margin above the needs of the device(s) you're providing power to (pump(s) in this case). The relay should also be rated at the appropriate current needed of the circuits it feeds.
For example, if each pump needs 8A, the wire from the relay to the pump should be fused at 10A. The wires from the relay to the pumps should be rated at more than 10A, probably 15A/. The wire between the battery and relay may should be fused at 20A while that wire should be rather at 30A or more which should be the current rating of the relay. Doing it this way provides some factor of safety above what is needed and the fuses will protect the relay and wiring. Anything less can't be described as professional, just neat looking
despite looking neat
I find it simpler to mimic what the vehicel makes have done as its usually robust (just ignore Holen pump connectors melting in this case). As such, i'd simply duplicate the wiring from the battery to the pump itself for your seciond pump using the same wiring size and relay to what currently exists. Something like this:
Code:
! !------fuse------->to own pump relay
! BAT !
