Fuel pump replacement E85
Aquamarine
45
VP Exec
93 VP series II Executive sedan, I plan on feeding E85 from the standard fuel tank to a twin pump surge tank in the boot and would appreciate advice on which pump to use in the fuel tank.
The smallest walbro E85 compatible pump is 450LPH, a bit overkill. I have been recommended to use a new standard replacement (non E85 compatible) and change it every few years. Thanks
Pollushon
Boost gives me a bar....
VY SS
Deatschwerks DW200 or DW300 could be a good choice. Solid pumps. There's nothing wrong with a bit of overkill keeping your surge well supplied depending on how thirsty the engine is on full song. Non ethanol rated pumps can corrode and come apart, not something you want happening in a fuel system
07GTS
Australia
VEGTS BUILT BLOWN E85
most 255lph and 340lph intank pumps can be ethanol safe and like above ^^^^ they are small 38mm so fit in most applications, Raceworks do a few also
