fuel pump
bjvan2003
hallam
1990 30th anniversary ea ford wagon
fuel pump has gone and was wondering if anyone knew where i can locate it?
its a 88/89 6 cyl. vn.
does anyone happen to know the price of a new pump also and is it an easy job?
1991_Vn2nV
Gumeracha, Adelaide Hills
91 VN Berlina & 03 VY Berlina
Im not entirely sure on the price... but depending on your knowledge its not an easy job. You have to de-pressurise the fuel tank and empty the fuel tank and you will find the fuel pump behind the fuel guage sender unit..
This recent thread tells you how to remove it from the fuel tank unit:
http://forums.justcommodores.com.au/showthread.php?t=38244
1991_Vn2nV
Heres the information I gave in the thread anyway... But before you get to this stage you must depressurise the fuel system and disconnect the negative battery terminal... Plus the rear of the vehicle must be raised and supported and then you have to empty the fuel tank with a hand pump or something.
1991_Vn2nV said:
Ok well Ya gotta disconnect the wiring connectors from the fuel guage sender unit and then loosen the hose clamp and remove the fuel hose hose from the fuel guage sender unit as well.
Then remove the retaining screws from the fuel guage sender unit and manouvre the sender unit and the fuel pump assembly from the fuel tank.
Disconnect the wiring from the fuel pump and remove the strainer from the fuel pump inlet.
Then ya just need to slide the pulsator along the pick-up tube until it is clear of the fuel pump outlet...then manouvre the fuel pump from the mounting bracket.
bjvan2003
hallam
cheers for the info. it'll give me sumthin to do on the w/end.
but wont impress the misses much!
2greedy
VP Calais (SSV)
Queensland
www.designaglo.com
VY SS HBD6speed manual 5.7ltrs of manual GRUNT!!!
as far as price goes m8 i bought 1 through autopro the other day and it cost me $115 but they range between 100 and 120
V
vp manual wagon
Guest
Hahahaha hope you didn't fill up before the barsted conked out on you! I hated the last time that happened......Mine didn't on the west gate, and i had to kick the rear end like a football just to get it to start and get off that bridge in peak hour... I F****** hate fuel pumps...grrr
bjvan2003
hallam
$25 worth of fuel which took it to a 1/4.
luckily i run gas too, but its sluggy as **** on gas!
going to get someone to do it for me. with labour im looking at about $190.
