wannaeatyourbrains
- Sep 24, 2019
- 591
- 544
- 93
- Age
- 52
- Location
- Mecca
- VZ Executive
Still having issues with the VZ running rough. Only 4 or 5 cylinders now. I have put in new coil packs, plugs, injectors, fuel filter.
There are no error codes.
Could someone enlighten me, are the fuel sender units interchangeable between all VZs?
I got one out of a 2004. Mine is 2006. I just noticed the fuel filter from the new one has a smaller diameter.
I have no way of checking fuel pressure, other than to say that when the engine is running, if I depress the Schrader valve, plenty of fuel sprays out. (Only for the brave hearted.)
Could fuel pressure still be the issue? Is it the wrong sender unit?
I actually suspect the ECU, cause the engine got wet, and it was shortly thereafter all problems started. I think the fuel injectors are not firing.
Would I get error codes for a malfunctioning ECU? Would it stop generating error codes for other problems?
Thanks in advance.
Thanks in advance.
