One bad plug lead doesn't generally cause it to run really bad, just a miss but it sounds like there could be many things going on. How old are the leads? How old are the dizzy cap and rotor?
There is a small hose going from the fuel pressure regulator to the intake manifold. Take that hose off and see if there is any fuel coming from there (indicating a failed diaphragm). Fuel pressure regulators tend to fail internally leaking fuel straight into the intake via the vacuum hose rather than increasing pressure.
You could have sick injectors, stuck open leaking fuel into the engine too.
Have you checked the ignition timing?
hi mate thanks for your reply. i never got it down to my mates like i wanted to. i have checked the vac line running from the reg to the throttle body and it appears to be dry. also i crimp the fuel line from the regulator and its not overfuelling from there. im waiting on the plug leads online, i ended up buying a oem set of holden leads. they will be here next week.
the valley gasket was done about 40,00kms ago ( approx ) the points and leads were done then. ive pnow put new plugs in, have anew iac to put in and also a new ignition module, i attempted to put the new module on the other day but the 2 fixing bolts just spin, so ithink i have to take the wheel off and the inner gaurd to get at it?? is that correct??
no idea how old the cap is, once i get the module on, new leads, clean the maf and put the new iac on we will see ho we go then, i was fumbling around around behind where the cap is yesteday and the coil was not frmly fixed to anything. im wondering if there is a problem there. and the cap seems to have a bit of play in it also. like the 2 spring clips holding it on were lacking a bit of tension. you are correct in saing there is a few things probably going on at the same time. do you think it best to pull the top off so i can have a good look around. i wouldnt have thought the coil would flop around like it does..
ive been thinking about selling it anyway as fuel is getting expensive etc and ive bought a hx one tonner that i would rather put my time into. to sell it i have have it running right. maybe it needs new injectors? do you know if bosch 973 injectors are compatable? theres a swap service available, old for refurbished. is that the way to go?
sorry for bombarding you with so many questions. the timing hasnt been checked at this stage.
i will put the leads, module and iac on and get back to you next week. thanks for helping
