T
t3zza
Guest
I have a VT 5L 5 speed manual, and it appears that there is oil leaking from the gearbox housing. I cleaned it all up recently but noticed that there is oil leaking from it again. I have noticed that gear change between 1st to 2nd, then 2nd to 3rd are a bit rough through the gears. I then put a fully synthetic oil in trying to solve the problem but no luck. It goes into gear alright but it doesn't feel smooth.. Could this be related to the gearbox leaking oil. I have head that the gearboxes do leak a bit, but how can you stop this or fix it. In regards to the gear changes being a bit doggy what is the best fix for this. I was thinking of using something like NULON gearbox conditioner stuff, would you recon this could help?
