gearbox
camo89
brisbane
95 vs excutive s1
hi guys just wondering if anyone knows if a 95 vs commodore gearbox will fit in a 96 vs statesman both v6 ecotech same with exhaust and extractors
Brett_jjj
Tamworth NSW
vs commodore
Auto or manual?If its auto, the trans will bolt up to the engine,but check the number of electrical connector pins in the transmission wiring connector,some have 12 pins-usually VR models or 4HDD type, others have 13 pins -usually VS models or 5HDD or 6HDD type, and they arent interchangable as far as I know because of the different number of wiring connector pins,so be sure to check the connectors pins before fitting it up...
camo89
brisbane
95 vs excutive s1
yer auto mate but the commodore is series 1 and the staesman series 2 proab be different does it mean the gearbox if stuffed when it is just shuttering still drives and down shifts when ya put your foot down it stunk really bad after getting it home after it happened
Brett_jjj
Tamworth NSW
vs commodore
Im pretty sure that as long as the electrical connector has the same amount of pins ,the trans will fit.
hako
Donating Member
77
Toowoomba SE QLD
VS11 BT1 V6
You've probably burnt/distorted the clutches - check your trans oil and it probably will be brown/black and smell burnt. Sometimes an oil and filter change/flush will fix this problem temporarily and will cost about $80 DIY, whereas changinbg the trans is hard work unless you have a hoist. As Brett says, if the pins match, the ser 1 trans should be OK.
