Gilmer drive
Immortality
Staff member
Sth Auck, NZ
NO
10 character thingy
edit: but then why would you want to. The serpentine belt set up is about the most efficient you can get.
There is a place in NZ that does do a gilmer drive conversion for LS type engines however it requires all your existing pulleys be re-machined which is a costly exercise and fairly pointless.
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
Apparently, from what I've read (can't remember where I saw it). That "wanky sound" is because the belt is too tight.
IF the belt is adjusted properly, it shouldn't sound any louder than a normal belt.
maxthedralf
adelaide
Ve Calais V
the point of a gilmer belt is to MAKE that sound. not be silent. but the big problem with the belt is that when it gets to temp it usually expands about 20% of its own mass. shrinking the internal teeth and usually pulling the pullys apart. usualy it will put so much stress on the alternator bearings that it will destroy it.
Grennan
Slayer of Stupid Threads
Glen Waverley, Victoria
VE SSV G8 Sportswagon
Its just the way the belt is made. Its supposed to make that sound/be a better gripping belt to help stop belt slippage and tightness is just a by product of that.
wraith
Hand over the dog bikkies
Demonicaland
VX V6 Berlina. 2003 VW Passat
Why would you waste that much for no reason? Much better things could be done.
UFO
I Believe
MY10 VE International Sportwagon SIDI 3L
Holy crap, almost $2k to make a noise and offer no performance benefit?
OP... put that money towards either a supercharger, or a dogbox.
You'll get sound AND performance.
Grennan
