good morning vs..v6
jewcat
Banned
61
newcastle
92 vp
have v6 vs its running very ruff... anyways when i turn it off theres like 2 or 3 clicking sounds when eng is off what would that be thanks for your time :idea3:
ephect
Donating Member
VS Acclaim V6
when was the last service? when was the plugs n leads last changed?
is it only running rough when idling? on acceleration? or stopping?
it could be a number of things, but you need to provide more details.
jewcat
Banned
61
newcastle
92 vp
did plugs leads fuel filter coils n module 4 days ago still same
jgtoranalc
Adelaide, SA
Holden Statesman VR HSV 5L, Holden Torana LC
About the rough Idle.... Check your Earth points. Clean them and retightened if needed.
(Another thing to do is get a wire and place it on the body and then alternator bracket and see if Idle goes back to normal. This is a direct test to see if you have a bad earth connection)
Have you cleaned your Throttle Body and your TPS?
Clicking noise.... Is it inside the car or coming from the Engine Bay?
jewcat
Banned
61
newcastle
92 vp
no smoke.. throttle body cleaned click sound from motor n the cas replaced what u mean a wire like coat hander to the bracket that on the motor
moneypit
adelaide northern burbs
vs calais
I think he means any electrical type wire, you are checking the earth to/from the motor to the body/battery (bare metal not painted) is working properly. A bad earth can do strange things, more common than you would think as they are 20 years old now.
No random coolant loss lately?
jgtoranalc
Adelaide, SA
Yeah sorry Moneypit is correct. Use any electrical wire. Have engine running and then place wire on. If Idle changes to a smooth Idle, then you have found your problem....hopefully.
