BlackVXGTS
- Aug 14, 2004
- 5,512
- 2,522
- 113
- Location
- Melbourne, SE
- GEN-F2 GTS A6, VS Clubsport 185 A4
It’s now incredibly simple to directly run this manual on any Windows 64 bit operating system including Windows 11. Saves having to run the manual on an old PC with a Windows 16/32 bit operating system, or running it on a 64 bit operating system using a 32 bit emulator such as VirtualBox or VMWare.
The application is otvdm/winevdm: - Run old Windows software in 64-bit Windows. You can obtain/install the application as follows:
https://www.dropbox.com/sh/yh9u0gvomnzv6cs/AAC2TZv26lIEvyBLUuVhrMPza?dl=0
Enjoy.
- Go to the web site
- Download the otvdm-v0.8.1.zip file.
- Unzip the contents into a directory – such as C:/otdvm, or whatever you prefer.
- Run the install shortcut contained in the directory two times. I didn’t use the other install (no console) shortcut – feel free to experiment if you wish.
- Reinstall VSCD by executing the setup.exe contained in the VSCD directory (this allows otvdm to capture the required DLLs etc. to run the program).
- Set up a shortcut on the desktop and type:
- Modify the “C:\VSCD” portion to reflect the actual location of your VSCD directory.
- I used the lion.ico file in the VSCD directory as the shortcut icon.
- Execute the new shortcut, press the File option on the top RHS and the standard VSCD menu will appear.
Enjoy.
