id tip yes.
mix water and oil, missing lossing coolant, low comp between pots. and being realistic its a standard n/a motor and i doubt youv been belting the **** out of it, very much doubt rings.
read up in your vl book about compression testing and various methods used to determine what it is.
get another head even, worth nothing, n/a turbo are the same.
send it off too get tested and new valve seats and valve guides. get the steam seals done too.
go and talk to wade cams, say uv got a n/a its pretty much stock id like alittle more poke while still maintaning nice street manners etc etc just something small
$120 is #### all, plus machining your lifter blocks $80 odd.
while its apart dont put the standard manifold back on throw a set of extractors on expect to pay $50 2nd hand, and find a nice exhaust.
enjoy it for what it is. and basic vl n/a with a little cam for a little bit more go that you were able to do your self.
