Greenfoam, the state of the rods after a race wern't to healthy lol, engine failures wernt due to piston shattering either hehe.
The point I was getting across is there is no set HP limit on a set of rods They should be rated with revs in mind, even a perfectly balanced billet rod will still banana if you push it to hard, but no need to get into engineering lessons!
Where did I say rod failure was the main cause of engine failure? :S I said they wern't to healthy, if anything, the fact they held together should be a testament to their durability.
All I was saying is there should be no concrete HP rating on a set of rods. A 400HP engine revving to 8000rpm will damage a rod long before a 400hp engine revving to 5000rpm will. (Basing it on HP vs. Revs with no extenuating circumstances ie. oiling issues, tuning issues etc.)
Or am I by myself with this one.
Wasn't trying to start arguments guys lol
how will my Procomp H-beam rods go when i am revving my motor to 7500rpm? they told me it will be fine at those revs. I am hoping to make at least 600hpYour bringing external influences into the equation. Outright HP has nothing to do with those external influences. Timing, pre-detonation, lean AFR of course will factor into rod longitivity (or lack of) regardless if it is a 300hp streeter or a 1000hp screamer.
I'm not saying that manufacturers don't brand rods by hp rating (simply because its easier to rate and simplier to compare) yes they do. Do I agree with this form of measurement to rate rods? No. There is to many varying factors in every combination, that you can't just say, these rods are rated to 500hp. Sure it may be an "ideal indicator" to base stength on, but it is simply false. HP does not affect torsion strength, casting quality, material grading of a rod, shock rating, yield strength, stretch, it has absolutely nothing to do with it but yes cylinder pressure can play a part. How fast a motor is revolving is the relevant and contributing factor.
When is cylinder pressure at its highest?
What factors contribute to cylinder pressure?
How does cylinder pressure relate to the peak HP of an engine?
