Hay guys will a hall effect sensor play up when the car gets warm n will it heat up under load
J Justo hsv New Member Joined Apr 30, 2013 Messages 26 Reaction score 0 Points 0 Age 41 Location Buddina Members Ride Vshsv Jun 7, 2013 #1 Hay guys will a hall effect sensor play up when the car gets warm n will it heat up under load
someguy360 Well-Known Member Joined Jan 29, 2011 Messages 4,116 Reaction score 6,593 Points 113 Location The Shed Members Ride Various Jun 7, 2013 #2 Hall effect sensors will be more problematic when hot than cold. What problems are you having, generally if there is a fault with the Hall sensor the car simply won't start
J Justo hsv New Member Joined Apr 30, 2013 Messages 26 Reaction score 0 Points 0 Age 41 Location Buddina Members Ride Vshsv Jun 7, 2013 #3 Thanks a coil will under load but want it
