Skylarking
- Feb 3, 2018
- 10,389
- 11,163
- 113
- Age
- 123
- Location
- Downunder
- Commodore Motorsport Edition
ADR 7 is depreciated (thus no more) and in fact it’s been replaced by ADR42/04 Part 15? which is in essence a place keeper pointing to foreign standards. Specifically, the section basically states we must comply with either SAA, SAE, BS, JIS, DIN, ISO or ECE Standards, or FMVSS 106 Brake Hoses standards.They won't accept screw on fitting brakes hoses for ADR 7 Whip Testing
But not having gone down the rabbit hole and seen the docs for the above foreign standards, I’m not sure whether these docs would specifically mention a technology wouldn’t be accepted for testing. Normally these things are technology agnostic and one just needs to pass the tests specified within…
However, I’m not sure though it could be old guys behind counters with old rules still stuck in their head, or indeed screw fittings are singled out and aren’t acceptable for some obscure reason, or more likely screw fittings just have a hard time passing the whip test… don’t know…
Whatever the case, if brake lines with screw fittings aren‘t stamped or labeled as meeting the above list of standards for brake hoses, then obviously they can’t be used on road cars…
As for dodgy workers pumping out substandard brake lines, it seems from what I’ve read that the BrakeQuip machines crimps and tests every braided brake line made (though only to 3000psi which seems low as mentioned already). So theses dodgy workers won’t make a bad batch so to say. Maybe not to the spec needed for race cars but not a bad batch…
In any case I’ll accept your experiences with crimped braided lines in race applications as being less than ideal and simply avoid them if ever I get into some serious Fangio action on some track…
