Having problems with the head unit or wiring
Joopjbc89
34
Hampton park
2009 holden calais
Hey I’m not to sure if it’s my actual head unit itself playing up or a I have a wiring issue… I have a 2008 ve Holden Calais with a stock standard head facia but also have a amp and sub and new speakers (kicker)
Started off with some of the speakers cutting in and out but now the facia randomly turns off and the aircon randomly turns on
Also the hazard lights randomly turn on from time to time
What do you think is the issue
Fu Manchu
WA.
Is the main HVAC harness plug seated correctly? Has a lever that pulls it down and locks it in.
Fu Manchu
WA.
If that’s all good, next isolate the amp and speakers. If the problem persists, well you are looking at a loose facia or faulty facia. Faulty HVAC module perhaps. Once at that point you really need a high end diagnostic tool to poke around the system.
Joopjbc89
34
Hampton park
2009 holden calais
Does the ve have a centre speaker also and how do you get to it?
Fu Manchu
WA.
It’s under the grill. Using a nylon trim tool, gently pry it off. You will not use a screwdriver like a Neanderthal. It will ruin the trim around it.
4” 4ohm speaker is removed from the crash pad by undoing four No2. Phillips head screws.
Then unplug the two pin wiring plug.
Then happy days.
images
  • Like
Reactions: Lex
krusing
Melbourne, Bayside
Thanks Fonz !
:p
