Headlight adjuster screw stripped
Kurtly91
30
Holden vy series 2 2004
Hi
Just wondering if the headlight adjuster screw can be turned with pliers?
ant797
bunbury
vy s
I dont know about your headlights but on mine they are adjusted with hex bit guess is screw driver or anything that can be wedged into the corners will do
ant797
bunbury
vy s
Oh i see you stripped it if there like these ones i dont see why not or a 8ml socket on back
Kurtly91
30
Yes there just like the picture , screw on top that turns the cog wheel
Kurtly91
30
I'll just try with socket like you said, I know I could of just gone and tried instead of asking the question. It was just that there new headlights and I was worried I stuffed the adjuster
ant797
bunbury
vy s
hit it with some wd40 and try turn it from the nob at the back 8ml i think or pliers if you dont have socket if cog for screw top is stripped
