Headlights staying on?
VG355
Wagga Wagga
304 wagon/vg commodore ute/hz kingswood/vk project
Hey guys i just fitted new headlights to my vg ute i installed all new globes but the lights come on as soon as the battery is connected. This ute has had a full rebuild and it has vs caprice loom fitted. Im thinking it is an earth problem but im no sparky. Any help would be appreciated.
VG355
Wagga Wagga
PS the switch is off.
MYVESSV8
Brisbane/GoldCoast
VE 6LT M6
failed relay maybe (stuck closed) switch contacts stuck on, if there was no earth no circuit, bad earth/shorted may also be creating the circuit, start with these see if there is a wiring diagram on here (google)
VG355
Wagga Wagga
ok cheers i have pulled the relays out and the lights stay on. the only thing that turns them off is to pull the fuse out. i may have to find another switch to test that. and when i turn the headlight switch on the front indicators come on. i may have to get a sparky to look at it.
accentstencil
68
Eschol Park, Sydney
WH II Caprice, 5.7 2017 Captiva.
Have you checked the fuses? I had my lights staying on and it was a blown headlight fuse (fuse 21 I think).
VG355
Wagga Wagga
yeah the fuses seem to be fine.
Nut Kracker
Donating Member
60
Echuca Vic.
VT SS 304ci (195i)
Are they oem head lights or after market?
Did you have to modify the plug on the head lights or loom?
Remember you do have VS Caprice loom fitted to a VG and it may not be compatible with the lights/electrical system,
even though the lights do plug in to the loom.
May be the polarity has reversed due to the loom........Run a multi meter over the head light plugs on the loom to make sure it matches
the lights.
Just a thought.
VG355
Wagga Wagga
yeah i spoke to a sparky and he seems to think the wires arnt matching up in the plug. they are chinese headlights.
