Headlights worked now not working...
Discussion in 'Electrical Wiring / Questions' started by Heeey!!, Feb 10, 2010.
  1. Heeey!!
    Heeey!! New Member
    VR Clubsport
    hi guys, im stumped and need sum help.
    i drove my car the other week at night, headlights were fine.
    since then removed dash facia to replace dash light bulbs, put everything back together, all lights work, parkers work, hi beam work, all dash lights work but my low beam headlights dont work.
    i have checked all fuses and relays, globes must be fine also coz when u flik hi beam on both low and high come on but low doesnt work by itself.
    anyone got any ideas as to where i can start testing coz im f***** if i know whats going on now.
    thanks in advance
  2. Majestic 36
    Majestic 36 New Member
    Looking For A VL
    You should start by back tracking all the stuff you just did and check that you didn't knock a wire out or something isn't plugged in right.
  3. PRAVX II S
    PRAVX II S Member
    Australia
    Commodore
    Check all the connections which you have disconnected.
    If thats all fine then check if there is power getting to the relay from the headlight switch (when the switch is on)
    And also check power at the headlight plug.
    Use a test light
  4. v6lux
    v6lux New Member
    VN S1 (was VR) V6 Hilux
    If you guys don't know, the headlights don't work if the BCM is not plugged in. This is something consider when fault finding!
  5. PRAVX II S
    PRAVX II S Member
    Australia
    Commodore
    Mate i know that. But if you read the question the parkers work and the high beam work.
    And the Bcm plug cant just come off unless they been tampered with.
    The best way is to check for the simple stuff then go in deeper.
  6. v6lux
    v6lux New Member
    My comment was intended for you, just a general hint for the OP!
    If you are saying the Parkers and High Beam work without the BCM, just say it is so!
  7. PRAVX II S
    PRAVX II S Member
    Australia
    Commodore
    I dont no what your trying to say.
    But the BCM controls the lights and other accessorys in the car.
    If the parkers and the highbeam come on way would it be the BCM? bro
  8. jafo
    jafo lurker since 2003
    adelaide
    1999 wh statesman
    take the globes out and replace them
    parkers are separate globes
    high beams are separate globes
    depending on which lights you have
    if this is not the problem at least you have a spare set of lights
