Heating?
Peter89
'90 S1 VN 3.8L A4 Wagon
my heating broke a year or so ago and i need one of these:
heater tap
however when i buy one, the heater will still be **** as always, since the fans in VNs are poor.
i would like suggestions for a bolt-on upgrade (or limited modifications) for the climate control fan, so that the heater can actually heat up my wagon on a cold morning.
any ideas people?
Peter89
anyone ?
wrx884
WA's ASR Rep
37
VT Exec/ VT L67 Spac, 5L VP Calais, 77 TC Gemini
so ur fans not blowing enough air 2 move the heat around is that wat u mean or r u just not gettin enough heat in general?? mayb check the heater core, could b blocked up? or faulty thermostat?
1991_Vn2nV
34
Gumeracha, Adelaide Hills
91 VN Berlina & 03 VY Berlina
The level of heat should be fine, if it is taking too long to reach the required level of heat coming out of the vents, perhaps check the thermostat as the car may not be warming up as fast as it should.
My fan blows sufficient air on the maximum setting, so im not sure if perhaps you have an issue there as well.
So is it the amount of air being blown out, or the temperature of the air being blown out?
88GreenVN
Next Exit Left
58
Surprise, Arizona
Dodge Ram Van 1500 5.2 V8
Are the heater pipes getting hot - by the drives side center console under the dash. If I have my VN set to hot after a while my leg gets warm if I lean it against the console. So it could be a few things.
I'd say your old heater tap may have been jammed shut or not opening enough.
Your core may be blocked.
The thermostate may be open all the time letting the coolant flow to fast and not heating up (you would have poor economy with this)
rob drag racer
vn vp drag nut
golden beach
forums.justcommodores.com.au
vp 3.8 with gas new project vn s1 guted strip only
i agree mine gets to running temp in around 5 min and i have to turn the heater down to half 5 min after that
Peter89
the amount of air.
the fan is weak as, always has been. maybe i just have a dodgy fan.
the heating system should work fine after i replace that part.
rob drag racer
vn vp drag nut
golden beach
well if the fan don't produce enough air flow to relay feel the air gushing out of the vents id say that the fan is defiantly bugged not the easiest to replace either (lots of Holdens magic screws "hidden" )
88GreenVN
Next Exit Left
58
Surprise, Arizona
the amount of air.
Also 1 thing to consider is that the vents are not opening all the way - ie vac leak maybe.
when you have the fan on 4 (flat out) it should make a real racket.:thumbsup:
