Help changing water pump on VL
iank1000
74
VL berlina
Going to have a go at replacing the water pump on a VL. from what Ive read I will replace the timing belt with a kit at the same time.
A few questions please. To get the harmonic balance pulley off its undo the pulley bolt. Being an auto what is the easiest way to stop the motor turning while undoing the bolt? Once I get the bolt undone & before I remove the pulley I am guessing I get cylinder 1 to top dead centre and verify the timing mark is correct and mark it. Same when I get the timing cover off do I mark the position of the belt pulleys before removing the belt? Any advise appreciated.
J_D 2.0
Ipswich
2009 VE SSV M6 on LPG and 2022 Kawasaki Z650L
You need a flywheel locking tool which will engage with the teeth of the flywheel/flex plate to stop it turning. You normally remove the starter motor to fit the locking tool.
Don’t make the mistake of just using the parking pawl and expecting it to lock it sufficiently as it has a high likelihood of breaking the parking pawl and then park won’t work.
iank1000
74
VL berlina
Thanks for the reply and the warning re the park pawl. I dont have access to a tool, are there any other options?
J_D 2.0
Ipswich
Not really. You have to stop the crankshaft from moving and the only way to do that is to stop the flywheel from moving.
Depending on the specific circumstances it might be possible to get another operator to hold the flywheel by wedging a flat blade screwdriver against the teeth of the flywheel but I wouldn’t like your chances. You will probably need to invest in the tool or pay a mechanic to do the job.
iank1000
74
VL berlina
thanks for the reply. I wondered if a quick burst with a rattle gun would be worth a try
J_D 2.0
Ipswich
If you’ve got a rattle gun with a decent amount of grunt then it might work.
chrisp
Melbourne Victoria
VF2 MY16 SS Redline Sportwagon
Cam belt on a VL is pretty easy to do. I had it down to 30 minutes at one stage (while I was playing around with the cam timing). From memory, it was undo the fan (but sit it in the shroud - it won’t come out over the shroud), then I undo the shroud and lift it out with the fan. Sit the fan somewhere vertically. You’ll have lots of room in front of the engine after this.
I had a manual (gearbox) so undoing the crank bolt was reasonably easy. The crank pulley requires a puller - the standard everyday type that uses bolts, but i can’t recall the thread size nor the length. Be careful as there is a key between the crank and the pulley and it can be easily lost (damhik!).
The covers over the belt come off easily. It’s good practice to move the engine until the timing marks line up. Remove the belt, remove the water pump, etc…
As you have an auto, you’ll have the remove the starter motor and wedge the ring gear somehow, or use a rattle gun.
iank1000
74
VL berlina
Thanks for the info. Looks like getting the crank pulley off is going to be the biggest job. What a design eh! To get to the water pump. You must have done a lot to get it to 30mins
chrisp
Melbourne Victoria
In the scheme of things, the VL cam belt is very easy. Most of the time is taken looking to see what bolts need to come out and what size socket to use. Once you know (or remember!) it’s very straightforward. There is lots of room after the fan and shroud is removed, so it’s pretty easy to see what needs to be done, but it is still a bit of contortion. Take your time - it’ll be easy enough once you have the crank bolt out.
The hard cam belts to change are the ones on front wheel drive cars as the clearances are very tight.
