help code 76!!!
danny1987
34
vs commodore sedan
help me i got a code 76 varition between left and right banks changed the oxy sensor now its gone but now when i put my foot down it feels like its not getting anough fuel its jumping up the road its only around 4-5000rpm and it was stalling when i got the code it feels like that still but it isnt staling now anyone got a idea?
kopper69
35
VRII Acclaim
Sounds as if the oxy sensors are not working properly. The gregorys manual should help you out. If you have a multimeter you should be able to get the voltage readings from them and see if that are out of range. aldl cable might also give you this info if you have a mate with one, wouldnt go and buy one just for that purpose tho.
danny1987
34
vs commodore sedan
found the prob that started it all i had water in the fuel tank lots of it went back to the last place i filled up but do you think they wonted to hear about it after $500 later its fine now running sweet fuel pump,filter,oxy sensors,injector clean,plugs and system flush. the last place i filled up on the day this all happened was a wollies at emu plains there has been 3 other mates of mine top up there with the same prob now
dmitch
DonkeySS
37
Perth W.A
VS SS S2
yeah this is becomin a big problem these days.. should start makin a database of where people think they r picking up comtaminated fuel...
