Help me start my vx wags
CunningStunt75
Surfers Paradise
Vx commodore wagon 2000
VX Commodore how do I check if if the see you is buggered or BCM is buggered how do I check problem was car would start and stop at random replace crank angle at cam angle sensor replace fuel pump replace coils and cool module and still car won't start if anybody's got any ideas what I could do that would be great ...VX Commodore how do I check if the BCMOUCU stuffed of replaced crank angle sensor I replaced coils coil module fuel pump but still won't kick over if anybody's got any ideas of you awesome.
Also scan tool will not register
awesome I appreciate your time thank you
lout
60
Langwarrin Victoria
what scan tool are you trying to use
is mode light going out
did you buy like this or just happened or gradually got worse
or happened after the parts cannon
CunningStunt75
Surfers Paradise
Hello well there were 3 different mechanics and 3 times it wouldn't read.
When first happened I replaced coils started then stopped again so replaced fuel pump, it went. Stop ..started..stopped..
Now hasent started again since.
CunningStunt75
Surfers Paradise
Mode light is going out
lout
60
Langwarrin Victoria
if one of the computers is offline
no amount of coils or fuel pumps will fix it
have you tried the display diagnostics yet
Trip computer diagnostic codes
Hold mode and up arrow then turn key to on or start
Release buttons
then
Press Mode = Dash Part Number - e.g. 1731
Press Mode = Mode Switch Voltage - e.g. BV - - - 5.0
Press Mode = Battery Voltage - e.g. V 11.8
Press Mode = Petrol Sender Voltage - e.g. FUEL 02.6
Press Mode = LPG Sender Voltage - e.g. VL 5.0
Press Mode = Remaining Fuel - e.g. 38L
Press Mode = Instantaneous Fuel (Liters per Hour) - e.g. 12.8 L/H
Press Mode = Engine Coolant Temp - e.g. 63 C
Press Mode = Vehicle Speed - e.g. 45 KM/H
Press Mode = Tachometer - e.g. 2380
Press Mode = Park Lamps Switch - e.g. P OFF
Press Mode = Dash Trouble Codes - e.g. t 00 (Press up/down to scroll through any codes, these are not PCM, ABS, etc codes)
Press Mode = Dash Test - All gauges will move, lights will come on and buzzer will sound.
Turn key off will revert to normal dash
Dash trouble codes
Format is t then code number then history then current some have nu which I cant remember but believe was not used
Eg
t00-- is fuel gauge sender open circuit no history and no current faults
t16h- is abs history codes but no current fault
00 Fuel gauge sender unit — open circuit
01 Fuel gauge sender unit — short circuit
02 Fuel gauge sender unit — intermittent
03 Fuel gauge sender unit — open circuit
04 LPG gauge sender unit — open circuit
05 LPG gauge sender unit — short circuit
06 LPG gauge sender unit — intermittent
08 No serial data from ABS
09 No serial data from BCM
10 No serial data from ECC
11 No serial data from PCM
12 No serial data from SDM
13 No instrument poll from BCM
14 No serial communication
15 No Sub-clock
16 ABS or ABS/ETC fault logged
17 BCM fault logged
18 ECC fault logged
19 PCM fault logged
20 SDM fault logged
21 Trip switch short circuit
22 Trip switch button stuck
24 EE checksum error
25 ROM checksum error
26 Internal fault
CunningStunt75
Surfers Paradise
Release buttons
then
Dash trouble codes
Eg
15 No Sub-clock
17 BCM fault logged
18 ECC fault logged
19 PCM fault logged
20 SDM fault logged
26 Internal fault
Hey thankyou so much for taking the time to help.
Very much appreciated.
I'ts my friends vehicle so I'm trying to relay the messages as best I can.
I have a video that he has just sent me. Could you have a bit of a look and see if there's anything you notice. Thanks
CunningStunt75
Surfers Paradise
I can't seem to attach this video. I'll get back to you
CunningStunt75
Surfers Paradise
So the sequence in his video goes
1) 12.6 bat V
2) 55.5 petrol V sender
3) 0.00 fuel P/hr
4) 19° coolant
5)0km/hr speed...
6) 3quick flashes
V6 5.0, V6 3.3, V6 5.0.
7) Too nu
8) all lights.
Fin
lout
60
Langwarrin Victoria
when you get to T 00
use up down arrows to scroll through the list
double check T 00 NU as i am sure it will have a fuel gauge sender
