Help VT 2000 Supercharger misfire?
shadowatcher
42
New Zealand
Commodore VT
Hey all,
What have i done :(. Replaced inlet gasket, re-kit injectors, flush cooling system. Now its misfireing and fuel appears to be running down the block by cylinder 1. Ive replaced sparkplugs and coils. When replacing plugs i noticed 3 out of 6 were wet. Ive checked vac hoses, plugs. Im not sure what ive done or what to do next. Any info and help would be awesome.
Thanks in advance.:D
ant797
bunbury
vy s
did you forget an injector oring or pinch it putting it in or even accidently left an an old one in there and doubled up on an oring
Utel67
Tasmania
Vs s3 ute
Take vacuum hose of fuel pressure regulator and see if it's leaking
commodore665
expat Saffa
52
New Zealand via Cape Town
2005 SV6 & Alfa Romeo 156 V6
possibly pinched an o-ring on the injector seats , or as above , fuel pressure regulator
Utel67
Tasmania
Vs s3 ute
We're all the wet plugs from the same side of the engine?
Have you checked for fault codes maybe O2 sensor causing over fueling.
shadowatcher
42
New Zealand
Commodore VT
Ok, no leakage from vac hose. Removed injectors and sprayed brake clean through them, i did notice when i shock the injectors i could hear a rattle but a couple had no rattle? Re installed injectors car ran abit better then started missing again with fuel running down the block and alot of fuel comeing out of exhust o_O. Injector failing?
