help with desing an spl sub box
impulsed_sv6
30
Mandurah
VZ SV6
i have 2 type R subs 12" and would like to kno any infomation and making a spl box for them as i will enter sounds comps when i can
acarmody
Donati..Whoa Green
VX Berlina
Bit of light reading but there is some sound advice in here. http://forums.justcommodores.com.au...e-building-some-spl-sub-boxes.html?highlight=
What boot dimensions can we work with here?
EDIT: Hmmm looking at the specs these things don't like large vented enclosures, Alpine recommends 1 - 2cu.ft vented. Maybe one of the installers has a different experience based opinion.
http://www.alpine.com.au/files/OwnersManuals/swr_1023d_1043d_1223d_1243d.pdf Quick reference for myself and anyone else.
impulsed_sv6
30
Mandurah
VZ SV6
red through the post some very helpfull infomation on it i have been reserching bit more aswell and from the knowlage i have gatherd i have designe a rectangle ported box
h14xd13xw17 using 3/4 mdf giving me volume of 1.29 vb
less the sub displacment 0.07 giving me 1.22 vb
tuned to 33 hertz wich is what i belive the type R tuning frequcny to be
using one 2.2inch round port calls for a leng of 5.68 inches
what are your thoughts on building this
acarmody
Donati..Whoa Green
VX Berlina
First go 1" MDF, any panel flex will hurt your score. Second, go at least 2cu.ft, while bigger isn't always better, 1.2cu.ft is pretty small. Third go a bigger port, 2.2" is pretty darn small, maybe some 4" like I went, 6" if you can wrangle it.
acarmody
Donati..Whoa Green
VX Berlina
OK using 1" MDF, with outside dimensions used. 400mm height, 450mm wide, 500mm deep, single 4" port with length 300mm with 25mm flares on both ends, should give you 2cu.ft Vb, with a tuning frequency of 35hz.
AmmoJammo
Adelaide, Australia
VL Wagon
you don't design an SPL box, you build it, test it, adjust it, till its right.
a single chamber box made from single layer 18mm MDF, and double layer for the baffle would be a good starting point, considering you may end up having to make another box anyway :p
somewhere around 100 litres total for both woofers.
you'll want to tune higher than 35Hz for SPL.
impulsed_sv6
30
Mandurah
VZ SV6
ok went to the local car sterio installer who is very good at what he does
he told me to make
1.2vb
1.4vb
1.7vb
2.0vb
use n test all 4 boxs with different lenght ports with a 4 inch dia port
and try make the ports firing into the parcel sheld once i removed the infill panels and leave them blank directly firing them into the cabin
vt josh
vt commodore
6 inch port mate dont use anything smaller
acarmody
Donati..Whoa Green
VX Berlina
While I agree with Vt Josh here, I must point out it is quite hard to make two boxes with 6" ports in each that will get inside your boot. Like what happened with me.
