Help with my VL N/A. Want to turbo it
Discussion in 'Straight 6 Development And Modification' started by indcnt85, Jan 1, 2012.
  1. indcnt85
    indcnt85 New Member
    Tarneit
    VL Berlina Manual
    Hey ppls im a new member so im not sure on what im typing in lol. But I really wanna turbo my series two VL berlina manual. and just want to double check on what i need to do so??
    Turbo Manifold/Turbo ETC
    ECU
    Injectors
    oil lines/water lines etc
    Is that all i need to run it straight up??
    later on ill get a lsd, disc brake diff and Cooler
  2. sweefu
    sweefu New Member
    VY Berlina V6 / R31 Skyline
    Hey mate,
    You need to use the search function, this has been covered in depth many times. On top of what you have mentioned you will need a stock cross-over pipe or an intercooler setup. Also don't forget to retard your base timining to avoid pinging, especially import with no cooler. Do you have the series I or II RB30? The series I has no oil/water lines tapped into the block unlike the series II.
  3. EVL-087
    EVL-087 I Live For This Shit
    Hobart
    VL Turbo (Toy) & VR (Daily)
