There is a raft of other VIN matched stuff on VE. Parking sensor module, abs module, TCM, cluster, headunit, HVAC, and someone could probably name more.
You will need the components you have put in, reflashed to match your existing VIN by a technician using a Tech2 or similar.
The VZ was just BCM, ECM, Key, PIM. The VE has heaps more attached to the VIN.
You'll have a mismatching modules and components and the car is doing what it’s designed to do in that situation and not start the car.
Best bet would be to replace only the component that needed to be replaced, get it reflashed and keep the other bits as spares.
