Motorculture
- Oct 20, 2011
- 735
- 5
- 18
- Location
- Sydney, Australia
- VY SS Commodore
Spool Imports specialise in High Performance Import engine parts as well as the more popular Australian performance engines. We have been in business for over 7 years and have a wide range of Spool conrods, pistons, crankshafts, ACL bearings, ARP head studs and more!
For our special Forum Members we have put together some special offers to take advantage of.
Holden Commodore VE / GM LS 5.7 and 6.0 Litre V8 I Beam Conrods and CP Forged Pistons Package
CP Bullet pistons are available for all LS engines running 6.125 inch rods and either 3.622 or 4 inch stroke.
Bore sizes are avail in 3.905 for LS1 and 4.005, 4.030, 4.065, 4.080 and 4.125 for other LS engines.
Numerous comp ratios are available for aspirated and turbo / supercharged engines.
Spool connecting rods feature:
- ARP 2000 fasteners (L19 fasteners are available as an upgrade)
- High tensile 4340 forged steel
- 2 Piece forging
- Hardness of HRC36-42
- Dowelled caps for precision alignment
- X-RAY & Sonic tested
- Quenching and heat treated
- Shot peened
- 100% Magnafluxed
- Weight Matched Sets +/- 1 gram
- Vacuum degassed to remove impurities
CP Pistons standard features include:
- 5310 gudgeon pins (9310 thicker wall thickness pins are available as an upgrade)
- Deep valve reliefs accommodate high lift camshafts
- Larger valve reliefs for +1mm valve sizes
- Custom skirt cam and barrel design
- Accumulator grooves
- High strength aluminium forgings
- High performance rings
- Fully CNC machined and balanced to +/- 1 gram
- Wrist pins included
- Double pin oilers force fed from oil ring groove
- Pick lock grooves for easy lock removal
- Pin fitting included
PRICE: $1,640.00 >> BUY ONLINE
Holden LS 5.7, 6.0, 6.2, 7.0 L ACL Race Series Bearings
Designed to withstand higher RPM conditions, ACL Race Series Engine Bearings are available for many of the popular 4, 6 & 8 cylinder applications and feature:
- High strength overlay plate with reduced thickness Hardened steel backs on all Conrod Bearings
- Increased crush and elimination of flash plating
- 3/4 grooving on Main Bearings providing optimum oil supply
- Tight consistent wall tolerances
- Oversize chamfers where applicable
PRICE: $ 297.00 (Please contact us to place an order)
All our performance parts are stocked here in Brisbane, Australia and we send items nationally and international usually within 24 hours of receiving your order. We keep our prices low by cutting out the middle man. When you purchase from us, you are purchasing direct from the importer.
SPOOL IMPORTS is here to help you in any way we can so feel free to contact us with any enquiries with the details below.
Website: www.spoolimports.com
Email: [email protected]
Phone: 07 3297 1074
Mobile: 0402 351 688
