Sammyscalais
- Aug 15, 2016
- 20
- 0
- 1
- Location
- Wollongong
- Holden VS Calais 5L
Hi
I got a Holden VS 5L and its killing me.
Long story short. It started with a mild miss under load when car was in 3rd or 4th between 1500 to 2000rpm. Fuel pump blew so got that replaced then its just been one thing after another since and its doing my bloody head in now.
Found coil lead faulty and burnt. Replaced coil lead and all spark plugs and leads, new coil, then had new injectors put in, someone said ignition module so did that too. Still not good. Found few codes coolant temp sensor, tps sensor. When changed injectors it started another problem. Was hard to start when hot. Checked o2 sensors and they were abit congested from running rich. Cleaned them and put back in. Any help, advice would be really appreciated. Don't know what else it could be. Dizzy button and cap was done about 1.5 - 2yrs ago. If you fang it sometimes seems ok but it doesn't have the up and go that it used to and its sluggish ad runs rough. Has anyone experienced this? What could it possibly be as everythings new. Even exhaust is too soo can't blocked exhaust.
