Hood problem
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by vsdeath, Apr 16, 2009.
  1. vsdeath
    vsdeath New Member
    1995 VS Sedan
    Hi there
    Anyone knows how to tighten the cable that activate the spring for the bonnet opening? Mine is too loose apparently and it makes the hood not to close/open properly.
    Cheers.
  2. vsdeath
    vsdeath New Member
    1995 VS Sedan
    Or maybe I need to change the spring itself... I have tried to pull it out and it showed me resistance.
    Anyone in here has experienced this problem please get back to me.
  3. holdenrocks
    holdenrocks Member
    VK Commodore
    need to be adjust the spring... will work as open well with cable cheers
  4. levymetal
    levymetal TURN MY HEADPHONES UP
    Somerville, Victoria
    HSV ENHANCED VP CALAIS
    if you need to tighten the cable (find your pulling the lever and it's just not opening), just tie a knot in it at the hood end of the cable. will work perfectly after that.
