VSIIBerlinaL67
- Jun 15, 2005
- 988
- 10
- 0
- Age
- 35
- Location
- Melbourne
- VX SS M6
i actuly looked up the power figures he told me it had 500 or so nm but only really has 200. so yer i get it now
Davey G force has outlined the conservation of energy principle to you. The energy from the fuel goes to heat which then gets transferred into moving energy in the engine. Then where does it go, into torque.....no, torque is not measured in Joules.The gearing behind the engine is what is doing the work over a given time, the engine is just providing the torque to make this possible.
Energy conversion yes, the engine converts the energy in the fuel to heat. This energy conversion pushes the pistons down spinning the crank shaft. The key word? Spinning. This is twisting force exerted by the crank, which is torque. The output at the flywheel and ultimately at the wheels is measured as torque, then it is converted via a formula to kW or HP.
It would pay to actually do some research before posting something contrary to what Ive posted, I only post on what I know about!.
Power is simply the product of torque and how fast the engine is spinning.
Sure a dyno measures an engine's torque and then calculates its power.
A petrol engine does use the force of the explosion to create its torque
An engine uses energy to produce torque.
Chemical energy stored inside the fuel is converted to heat energy which is converted to kinetic energy.
This is correct, however:
This is also correct. Torque is a moving force, kinetic energy is also a 'moving force' as such. So torque is actually energy. The energy goes from the fuel, to the piston etc etc etc to the wheels, and is then transferred to the car itself when the car is moving. Or in this case is transferred to the dyno. For the dyno to measure anything energy has to be physically transferred to it.
OR I'm just talking ****. But that's how I see it anyway.
Unfortunately your own take on some of it is incorrect. You display some confusion between force and energy.An engine doesn't produce power
vt748:
(I am qualified in this area as it appears also for Davey G). Perhaps get someone qualified in physics or engineering that you trust to go through it with you.
you are really stuck on the idea that since we calculate the power from the torque and RPM of the dyno, then there is no such thing as power
