How do i perform an error code check?
vs_commy5506
97 VS BT1 Commodore
People have been saying to perform an error code check if you think something is wrong with your car.....how do you dont that? dont you need a scan tool?
burnz
dah dut dut da dah
springfield
VFII SS ute M6
use a paperclip and bridge pin 5 and 6 , light the ignition (do not start) and read the codes, (themo fan runs if done properly)
code's blink 10's and 1's with a small pause (a larger pause indicates a new code) reapeting the 10's and 1's
Just Commodores - For All Your Holden Commodore Needs
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
Thermo fan doesn't run on the VS.
Each code will display three times starting with 12 and ending with 12.
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
Mine never did, and the two other VS's I have checked didn't either. The VN we have does though. All V6's though.
TUF UTE
Dave
adelaide
05 VZ SENATOR
havent done much searching have we lol. theres about twenty threads on here that tell you how to do it
and yes on my 5L the thermo switches on when i do diagnostics
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
yip V8 runs the MAP based ecu may make a difference to the fan ide say
