i own a 5 litre manual vt clubsport
I replacing the oil pump, how do you prime the pump,
ive heard that you put vasoline in it, is this correct, if so do you pack the whole pump full of vasoline, or just lube the gears and gear shaft then fill it with oil and fit the pump (filter included) to the car
