how do u wire L.E.D neons 2 ignition?
bomner12
33
nsw
vt ss ls1
like subject says..
i have a vr ute i want to wire my 2 L.E.D neons to ignition at the moment i have them plugged into my cigaret lighter using a double adapter i want to have a free cigarette lighter so how can i wire the neons up to the ignition then wire them both upto a switch??
i know a bit about electronics but not cars electronics
bangers
42
NSW
EL FALCON XR6
why wire them up to the ignition? why not JUST a switch?
bomner12
33
nsw
vt ss ls1
if i just have a switch i would most probably leave them going by accident same reason y ppl have there headlights so when u turn the car off they turn off
maginoodle
vy series2 ss crewman
put a switch in then get the power from a wire that only has power when the ignition is on(the ciggy power etc) or you could get your earth from the door sensor wire so that they come on with the door opening if thats what you want
bomner12
33
nsw
vt ss ls1
wiring
yer i think im just going to wire a switch to the cigi lighter then from the cigi lighter have the neons that will work wont it?
maginoodle
that will work but you will only be able to use the lighter when the neons are on. Just splice into the power wire to the lighter and the put your switch to your neons
bomner12
33
nsw
vt ss ls1
oh yer.. yer i might just do that lol
ill do that tomorrow im painten my brake calipers at the moment
