How much power can a Getrag 5spd Handle
fluxxx
Perth, WA
VY Acclaim S1
Damn, how much effort is it to put a t56 onto a ecotec??
i want to know this too, and if its possible. cant seem to find an answer from anywhere so if you find out id be keen to know. :thumbsup:
STEALTHY™
So Wet For You!
SA - The Roadworks State
PM BlownVs for exact numbers
But he was running a turbo on his, and with more than 200kw at the rears, held up perfectly fine.
The clutch however, always seemed to play up when Skye was driving, wierd that:p
Jesterarts
Your freedom ends where mine begins
2010 Nissan X-Trail ST-L
Is that 200rwkw with the Getrag or the t56?
Pretty impressive if the gertag held up with 200rwkw!
Yeah, the clutch would be sumfin to upgrade probably...
im gettin slippage atm and thats only running about 170ish at the fly!! lol
fmlycar
6appeal
Alice Springs
308rwkw 180sx
I think there is a black VY ute V6 on here that is running 355rwhp through the getrag M35. I'm sure with a decent clutch you won't have too many problems. Maybe look into a short shifter with positive stop to reduce over throw and rooting the syncros.
As for your slippage, I would put that down to crap factory clutch. When you upgrade your clutch you will have to replace the flywheel as well cause the getrag run a dual mass flywheel from factory.
STEALTHY™
So Wet For You!
The box is the standard box used on a series 2 VS V6, so i assume thats the getrag, not the T56. (haha, it was only a 5 speed, so of course it was)
The clutch wasn't standard tho. Like i said, PM BLOWNVS and ask him the specs, cause i only drove it, never worked on it.
Raptorsc
RAPTR6
Cairns Qld Australia
www.raptorsc.com.au
Hilux 4.0 V6 SC 400kw
The life of the Getrag seems to have less to do with outright power than with abuse. A customer of ours has been hard on his and yep destroyed 1st gear, however no one else has yet so I suspect it more driver related than power related. We have taken the precaution of informing people there could be an issue but maybe we are being mislead by just the one instance we know about at this time.
Hope that helps
Stupa
VU Storm
So if you stop dropping the clutch from 5grand it should be ok?
fmlycar
6appeal
Alice Springs
308rwkw 180sx
Make sure you got enough oil in the box too. From what I know and have experienced the M35 will use oil. Look after it and keep it serviced and you should be fine.
Stupa
VU Storm
Would ther ebe any hassles in changing to the t5 from a getrag?
Jesterarts
im guess ing just an adapter plate... not even that...
Cause the VS ecotec 5-spd had the t5...
Yeah, i don;t often find myself dropping it from 5G lol!!
Once in a blue moon of the lights i light them up from about 3000rpm
But i regularly drop it into 2nd @ 4500rpm... that would probably kill it...lol
