glad its appreciated.
heres a couple of others:
1. How to get rid of carbon deposits on your valves without pulling the head off your engine-for carby vehicles only
first warm the car up,then open your bonnet(duh,lol)
remove your air filter assembly to access your carby.
average idle is around 1000 rpm for most cars. with the filter off use one hand to increase the rpm to around 2-3000rpm or higher
(or even a bit higher but dont rev the shite out of it & make sure to keep it at a constant rev!! this is important)
then with the other hand slowly pour a cup of water down your carby.
by now some of you are thinking holy shite is this guy nuts,water & petrol dont mix etc. answer is yes i am crazy but not nuts
what happens is the water burns off the carbon deposits on your valves,because the engines warm & revved up a bit it does nothing but burn
the carbon off your valves. this works & is real old school.
i have seen this done in various ways for injected engines & done it myself but its a bit more complicated & tricky for the average joe
2: fanbelt squealing like a bastard,rub the inside of a banana peel or bacon rind on the fanbelt(obviously the side where it runs against the pulleys
doesnt always work & doesnt always make it disappear completely but worth a go if you got no choice.
isnt permanent & again recommend proper repair at first opportunity.
your fanbelt usually squeals in the first place because its stretched to buggery & will require replacement. also check your tensioners as they may be on their way out which could also be why your fanbelts a bit loose.
3: cars missing like a bugger,check your spark plugs as you might have one or 2 fouled plugs. if so get a bit of sandpaper & just give them a good clean up. should resolve the problem but you eventually will have to suss out why they got fouled in the first place.
4: never throw out your chinese takeaway plastic containers. bloody handy to put your nuts,bolts,screw etc in. they are clear so you can see whats in them,easy to write on the lid whats in them & your able to stack them. if your going to pull something apart & dont have these just shoot down to the local stationary shop or supermarket & get some handy clear seal bags. then if for arguments sake you pull the whole front of your car apart you can have one bag for headlight bits,one for guard bits etc. just write on the bag where they came from. then when you go to put it back together you will know straight away what goes where etc. you will also be able to tell whats missing right away.
5:have a commodore with a factory radio? well you dont need no fancy genuine holden stereo removal tools. just get a bit of wire coathanger cut into two reasonable lengths,then bend the lenghts to roughly the distance between removal holes & hey presto instant genuine stereo removal tool.
c'mon guys & gals,you cant have all been raised on if its broke throw it away & buy another. some of you must be able to throw in your 2 cents worth. at this rate i'll have no tricks of the trade left up my sleeve,lol. so add your own.
again i will add,some of the repair methods are not permanent & will require proper repair at first available opportunity
in this little segment suggestion 2 with the fanbelt is the only one that will need proper repair. suggestion 3 will help you out but as has been said you will have to figure out why one or more plugs are fouled. the rest is just handy hints & a bit of common sense. before anyone says anything about sanding your plugs etc with sandpaper,it does no harm. machines are even sold with emery paper(sandpaper of sorts) attachments for cleaning your plugs up.
good luck,have fun & happy motoring
